- Engine family: EcoBoost
 - Displacement: 3.0 liter
 - Aspiration: Twin turbo
 - Configuration & cylinders: V configuration, six cylinders
 - Vehicle engine orientation: Transverse / longitudinal
 - Valve configuration: Dual overhead cam (DOHC) with variable camshaft timing (VCT)
 - Assembly sites: Lima, Ohio
- Bore: 85.0 mm
 - Stroke: 86 mm
 - Compression ratio: 9.5:1
 - Max power @ RPM: 494 hp @ TBA
 - Max torque @ RPM: 630 lb-ft @ TBA
 - Cylinder head: Aluminum
 - Cylinder block: Cast aluminum
 - Camshaft drive: Chain
