Ford Bronco Raptor 3.0L EcoBoost Engine Specs
Kevin C
Pasadena, CA
Ford Bronco
  • Engine family: EcoBoost
  • Displacement: 3.0 liter
  • Aspiration: Twin turbo
  • Configuration & cylinders: V configuration, six cylinders
  • Vehicle engine orientation: Transverse / longitudinal
  • Valve configuration: Dual overhead cam (DOHC) with variable camshaft timing (VCT)
  • Assembly sites: Lima, Ohio
  • Bore: 85.0 mm
  • Stroke: 86 mm
  • Compression ratio: 9.5:1
  • Max power @ RPM: 494 hp @ TBA
  • Max torque @ RPM: 630 lb-ft @ TBA
  • Cylinder head: Aluminum
  • Cylinder block: Cast aluminum
  • Camshaft drive: Chain
