![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_1.jpg](https://www.broncoraptor.org/data/attachments/11/11411-6e95c5a7641476f72fcf3f7180f9f168.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_2.jpg](https://www.broncoraptor.org/data/attachments/11/11412-c71d6c860ebcbd990bcf9e8e379b4d55.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_3.jpg](https://www.broncoraptor.org/data/attachments/11/11413-cdf0782b035234809e0b17d7e62db5ec.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_4.jpg](https://www.broncoraptor.org/data/attachments/11/11414-b62f53c20e369471b94ea3adbd25d52b.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_5.jpg](https://www.broncoraptor.org/data/attachments/11/11415-bd83553418dd88ce0be8415e8ee6e97e.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_6.jpg](https://www.broncoraptor.org/data/attachments/11/11416-dc46877c5f78953e14e69e2aa909d359.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life_7.jpg](https://www.broncoraptor.org/data/attachments/11/11417-90c9124e41c6a1427cd2e2b975152727.jpg)
![ford-uses-animations-and-avatars-to-bring-the-bronco-raptor-cockpit-to-life-185887_1.jpg](https://www.broncoraptor.org/data/attachments/11/11418-18a4783a15c6191ceca87bdb605add63.jpg)
Normal: The screen of the digital cluster uses a subtle blue to show the vehicle in an everyday driving scenario.
Sport: Feel of a more exciting drive experience, with the cluster using a red and white theme to show the vehicle in a track environment.
Tow/Haul: To highlight the increased tow rating of 4,500 pounds, the cluster screen includes a vehicle towing a trailer, with the gauges turning yellow in a subtle nod to construction vehicles at work.
Slippery: Optimized for use on slick roads or loose surfaces such as gravel, this mode is replicated on screen using light blue to show a vehicle in rainy conditions.
Off-Road: An animation of an off-road environment in shades of brown to illustrate that Bronco Raptor is ready for muddy, rutted, uneven terrain, and that four-wheel-drive lock is engaged.
Baja: A cluster that uses orange highlights to show the vehicle driving across a desert scene.
Rock Crawl: Optimized for low-speed, aggressive climbing maneuvers, with the cluster showing Bronco Raptor slow-crawling over rocks.
