A BUNCH of Steeda Autosports IN STOCK here at Lethal Performance!!
Happy 2024 to our Explorer ST Owners out there!
We’re starting off the New Year with a fresh stocking of Steeda Autosports components and kits for the 2020 and UP Explorer ST!
Check out some of the fresh stock below!
Steeda Ultimate Handling Package (2020-2022 Explorer ST) - 555-2138
Kit Includes:
555-1030 Adjustable Rear Sway Bar
555-5734 Strut Tower Brace
555-8203 Lowering SpringsImproving the looks, rigidity, handling, and steering response, this kit brings the best out of your Explorer or Explorer ST.
Grab yours here! : https://www.lethalperformance.com/s...g-package-2020-2022-explorer-st-555-2138.html
Steeda Rear Differential Brace (2020-2023 Explorer ST) - 555-8141
Lightweight, yet ultra-strong, 6061 billet aluminum.
  • Dual bushing support.
  • Compatible with single and dual differential bushing designs from the factory.
  • Easily change diff fluid without removing the brace.
  • CNC-machined in-house at their Valdosta, GA facility.
  • Grade 10.9 and 12.9 hardware included.
  • Zinc plated washers and spacers.
  • Billet steel locating sleeves increase strength and rigidity.
  • Optional stiffer bushing set can be added to the kit for those that are looking for maximum performance at the track and do not mind minor NVH.
Grab yours here! https://www.lethalperformance.com/steeda-rear-differential-brace-2020-2023-explorer-st-555-8141.html
Steeda Pro-Action Rear Shock Kit (2020-2023 Explorer)
Perfect for those looking to match their stock ST suspension OR upgrade up their lower trim model to the ST’s level, Steeda’s Pro-Action rear shock kit will give you lighter handling and a more responsive feel.
  • Improved handling
  • Increased control and response
  • Retains comfort of the stock suspension.
  • Upgrade to Base, XLT, Limited, and Platinum trim levels
  • Performance equal to ST trim levels
Grab them here! https://www.lethalperformance.com/s...shock-kit-2020-2023-explorer-st-555-8437.html
Check out everything Steeda for the Explorer ST here!
https://www.lethalperformance.com/search/?q=Explorer+ST+Steeda
As always, if you have any questions or need some help in finding your Steeda mods, reach out with anyone of us here at Lethal Performance!
