Rotora Brakes 20% OFF!! Lethal Performance Spring Sales!!
If you're making some good power, you need equally as good stopping power!
To achieve this proportional front-to-rear brake bias, Rotora’s brake systems are strategically engineered to work in conjunction with the original vehicle stock master cylinder thereby producing shorter stopping distances.
In using larger calipers and discs made with stronger, lighter weight material, Rotora Brake System’s thermal capacity and brake torque is increased over the vehicles original brake system.
Check out the entire lineup here --> SHOP NOW | Rotora Brake Kits
Check out all of our Spring Sales in the link below!
LETHAL PERFORMANCE SPRING SALE
LAST DAY TO SAVE!!
20% OFF Kits & Accessories here at Lethal Performance! Don't miss your chance to save BIG on these kits to your ST the stopping power it needs!
