Kelltrac Viking Rear Shocks for Explorer ST are now available here at Lethal Performance!!
Hey #teamlethal Fans!
Kelltrac Viking Rear Shocks for Explorer ST are now available!
These fully adjustable shocks are physically similar to and built upon the legendary Viking Double Adjustable shocks, but have their own Kelltrac twist on them. With Kelltrac’s billet aluminum adapters, these shocks will fit and function perfectly on any Explorer ST.
Currently, only the Street version is available, which is perfect for the average person who wants a better shock than the OE that provides full customizability.
Coming soon will be the Street Strip version, which is for the highly upgraded daily driver types with over 500hp, followed by the Race version, which is meant for the max-effort, record setting builds that require the most travel, traction, and performance.
Benefits:
-Easy to access adjustment knobs to control ride comfort, handling and straight line performance characteristics.
-Shock design retains factory shock mounts and factory dust boots (provided with OEM style bumpstops).
-Increased bump travel for the off road crowd, or the high powered drag race launches! (2" more compression stroke available.)
-Extremely capable shock valving to set ride comfortable or control 1,000HP.
Check them out here!
https://www.lethalperformance.com/s...-st/lowering-springs/shocks?manufacturer=2237
USA
20 Platinum
I take it these will fit any Explorer trim? And great to hear we finally have a different set of shocks to go with. Viking makes great products, so glad to see that
The only confirmed fitment at this time is the ST. There may be support across trims, but we are not comfortable with releasing that information until tested
UNBROKEN
5000 Post Club
Houston, TX, USA
Shock mounting and dimensions are the same across all 6th Gen models. Another vendor even sells ST shocks and struts as an “upgrade” for other models.
