2025 ST High Flow Catted Downpipes!
CV Fabrication High Flow Catted Downpipes for 2025 Explorer ST are NOW AVAILABLE!
With some slight changes to flange design, these updated Downpipes from CVFab still feature their reinforced rhodium high-flow 700 CPSI cats that will not activate check engine light, all TIG welded from 3" T304 Stainless Steel, and will now fit perfectly to your 2025 Explorer ST. Backed by CVFab’s Lifetime Warranty, you can install these downpipes with the confidence you’re getting not only better flow and performance, but a quality exhaust product that will last the life of the car itself.
Not to forget the added exhaust note and turbo noise!
Check them out for yourself here at Lethal Performance!
CV Fab Stainless Steel Catted Downpipes (2025 Explorer ST) - EST25CDP-1
Charlotte
2021 Ford Explorer ST
Is this “upgraded” downpipe simply not applicable to the 20-24’ models?
Jacksonville, FL
2025 Explorer Plat 3L
So, no need for defoulers?
UNBROKEN
5000 Post Club
Houston, TX, USA
They need defoulers. Almost all aftermarket downpipes do. The only ones that don’t are using GESI cats at 3X the price. Those are also the only ones that are truly EPA legal.
Jacksonville, FL
Then this statement is misleading "...their reinforced rhodium high-flow 700 CPSI cats that will not activate check engine light" Can't you use defoulers on pretty much any aftermarket downpipe and achieve the same results?
Cruising68
2000 Post Club
Chicago, IL, USA
Just an fyi, I am running SPD downpipes 2 years now with no defoulers and no issues.
Sent from my iPad using Tapatalk
UNBROKEN
5000 Post Club
Houston, TX, USA
I’ve had SPD’s on with no defoulers since the first batch they made. Doesn’t erase the fact that almost all of them need the defoulers. CVF includes them for a reason. Some brands even have the defoulers built in so unless CVF changed to that J style O2 bung or changed cats completely…they would need them. It comes up damn near daily it seems like in my FB group.
Cruising68
2000 Post Club
Chicago, IL, USA
Seems most need them.
Sent from my iPhone using Tapatalk
